TV will not turn on, no red light
First make sure that it is plugged and properly connected to the power source. If it's properly plugged in and you still don't get the red light, check the power outlet by looking at your circuit breaker. Make sure that the breaker supplying the outlet for your television is turned on. If not, reset the breaker by turning it off and then turn it on again. Bottom line is, if you do not have a red standby light, it is most likely that you are not getting any electric supply to your tv.
Fix14
