LG LHD45EL Dehumidifier Logo
R
Ray coffman Posted on Dec 16, 2015
Starts, then stops. Why does display show code ch. 01?
3 Related Answers
Anonymous
  • 121 Answers
  • Posted on Aug 04, 2008
SOURCE: LHD45EL Dehumidifier won't run
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 1 year old.
Anonymous
  • 121 Answers
SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Stanislav
  • Posted on Nov 12, 2012
SOURCE: i have a lg dehumidifier ld650eal. it has a code
Unplug power cable,then take of front panel (2 screws).Then on left side on pipe se cliped sensor on pipe ,unclip then put in hot wather for 5 sec. Then put all back together and plug cable power and turn ON.That works on my Dehumidifier LG LD650EAL.
1helpful
I have a code on the screen CH 01... What do i need to do to get it to run again???
CH 01 Indicates that water collection tank is full and needs to be removed & emptied. Turn the unit OFF and unplug it, before removing the bucket.
My dehumidifier will not turn on. The two digital displays just read CH 01 It is a model # LHD45ELT8
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Unit shuts off. CH 01 shows on display
heatman101
1helpful
What is a code CH 01
Had same erroe code in 2008. CH 01. Bucket Full light was flashing, but it was empty. Would not start. Called customer service and was advised it was most likely a compresser problem. In that compressoe was still in warranty took it to a lacal service center. Compressor was Ok, but had to replace Evap Thermister Board and Sensor. $120.00 in parts and $50.00 labor.
I am not an expert.
Good luck.
2answers
Code (CH) (01) on front panel, what does it mean?
I believe it is a water tank code. Re-seat the tank, unplug wait 15 seconds and replug the power cord and see if this resolves the error.
Background relating to other possibilities.
When the water bucket reaches its capacity, the bucket switch opens to shut off the dehumidifier. If the bucket switch fails while it is open, it will prevent the dehumidifier from running. To determine if the bucket switch is defective, use a multimeter to test it for continuity. If the bucket switch does not have continuity, replace it.
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
1helpful
2answers
LHD65EBL Code CH 01
I had the same problem, and I wound up calling LG's customer support line. The rep I spoke with says that the "CH" code means that the internal thermostat is not able to accurately read the air temperature, and the unit will require servicing.
She gave me a couple of numbers for local folks, and I'll call them in the next day or so, but I'm thinking that this may not be worth the repair, unless it's pretty cheap: I bought the unit for under $100 less than 9 months ago, and I'm not eager to shell out a bunch of money to get it repaired.
1helpful
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
