Yes it should drivers, that's what make everything work. When you do an update Microsoft will at some stage include Driver updates as well, that is why Updates are so important as they keep your Tablet computer, working as it was designed with the improvements to the system over time. Now I started with a Surface 2, and then over time I upgraded to a Surface Pro 3, then a Pro 4, which I have at the present time. I made sure mine had 16 gigs of memory and 256 gigs of storage which I find is all I need as I use an external drive of 1 Terabyte for storage. I also found over time that if the charge is dropping while in use I just put it back on to charge to keep the battery well charged at all times. By doing all these regular housekeeping duties with the Surface, they have never let me down. I like my Surface Pro 4, you probably would to, but now they have Surface Pro 6's on the market and they are just the best of Tablets that you can buy, even though a tat on the dear side, but that's what you get when you buy Quality. Best of luck.
