Question about Westinghouse UW32S3PW 32" LED TV 1366x768, 60 Hz, HDTV
TV shutt off and on
TV works for 1 minute, then shut off for a few second, and ON by itself, and off again, etc, etc....
    Top Expert:
  • Westinghouse Master
  • 76,204 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 17, 2015
6ya staff
SOURCE:
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
My tv shuts itself off!
Quite a long "description". "How can I fix it without having to check the back of the TV or going to a repairman?" (I altered the spelling etc a little there.)
Answer: Go to the internet and search for "Magic TV Repair Wand" and let me know if you find one---
Apr 28, 2012 | Emerson Televison & Video
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
HP Pavilion MD5020N 50 in. HDTV DLP TV keeps shutting down
ok this is what you do folks.... un-plug the tv from the power supply. once that is done hold the power button down on the side of the television for 30 seconds. this will release all electricity out of the tv.... then before you plug it back in hold the channel down vol up button along with the power button at the side on the tv this should reset the tv and it will start up automatically on video one. Select your source and scan for your cable channels again. If the problem is not solved then contact someone to come and clean the filter for the tv because it may be clogged along with this it can be the color wheel and may shut itself off like 3 times until it feels it is right.
Apr 08, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Tv wont come on
You may have some type of short INSIDE of your TV .Your TV is trying to turn on and RESETS itself to try again. If you have an EXTERNAL [black box],(usually means power supply, power adapter,etc.) power supply, that!! could be at fault. not giving the proper voltage, current, causing the machine to fault. If you can exchange a known working power supply to see if that is the problem.
If you don't know what you are doing, don't go inside of the TV. There are circuits that can hold a charge of electricity that can & will hurt you.
Oct 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
Feb 22, 2008 | Cooktops
Westinghouse UW32S3PW 32" LED TV 1366x768, 60 Hz, HDTV Logo
44 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
