TomTomApr 15, 2013 - If you only charge your TomTom while it is in use, it may not charge to capacity. To fully charge your TomTom, it is best to charge the device indoors. Most newer TomTom products can be charged directly through USB, simply by connecting the USB cable or dock to your computer.
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Dear, first of all try cleaning the pins of your charger and mobile charging socket with petrol or kerosine oil. then see if it works, if still the problem persist, then their may be the fault in your charger or mobile charging socket. Or electric socket where you put your charger for charging! try charging your mobile by putting your charger in different switch board, if still it wont work, then try charging your mobile with different charger, if your mobile is getting charge, then get sure that problem is in your charger, its time to buy a new charger. original charges cost=900 duplicate charges cost=100
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Buy a new charger. If your computer charger works, and either your house or car charger are not working it is whichever is not charging the phone that is the issue. .
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
