Question about Samsung Washing Machines
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
The belt is fine capacitor is new when i do wash is working the problem comes only when i suppose to spin it sounds as if is spinning but it is not spinning the inner drum moves very very slow you can see it wants to spin but it looks as if there is something holding the drum not to spin.
    Top Expert:
  • Samsung Master
  • 53,770 Answers
Check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
Posted on Dec 18, 2015
Anonymous
SOURCE:
Clothes come out of washer wet
Most often you have a worn out belt that spins the drum when it is time to spin dry. Upend the machine and check the belt, if it has one.
A new drive belt should fix you right up.
Mar 14, 2016 | Washing Machines
Sometimes won't spin at all unless you let it cool down or sit for about 10 minutes first. When it does spin, it does so increaslingly poorly and sometimes even leaves some water in the bottom. It also...
sounds like a belt problem, also sounds like its overloading your electrical, when the belt cools down it is contracting enough to start pulling again, that belt is constantly working during all phases of the wash cycle. by the time it gets to the spin it has gotten pretty warm.
Dec 22, 2010 | Washing Machines
The spin cycle will not run on the regular wash. Once the switch points to the SPIN, the noise is present, but there is no movement within the washing machine. The dial continues to move until the supposed...
Check the pump drive belt. It may have come off.
Sounds like the motor is spinning but the pump belt isn't spinning the pump.
Pull the front cover and look under the machine for the belts.
K
Jul 09, 2009 | EuroTech Washing Machines
How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Jun 10, 2009 | Maytag MAV4755A Top Load Washer
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
K
May 10, 2009 | Washing Machines
Washer Won't spin & smells burning when it goes on spin
Hi there.I think it could be that when the belt was changed the bolt wasnt tightened onto the flat side of the spindle.I am talking about the small pulley that comes off to replace the belt.It has one flat side in which the bolt needs to be otherwise it might just spin because the laundry weight. Quick question I have this machine and it needs a replacement belt.I cant find one anywhere!!!!Where were you able to find one???? Good Luck
Feb 19, 2009 | Danby DWM99W Top Load Washer
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Sep 04, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
139 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
