Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Reason number 1:
Explanation for ERR1 1. Motor doesn't operate; ERR1 appears. 1-1. Explanation: Drive board has not sent power to the motor, so the motor doesn't operate; the optic sensor signal hasn't returned to the display board. This is caused by either a bad mcb or a faulty motor.
Reason number 2;
Reason for ERR1 2. Motor operates; ERR1 appears 2-1. Explanation: The motor operates; the optic sensor signal didn't reach the display board CPU; ERR 1 appears. In this case the issue is more than likely a faulty speed sensor or a there is dirt, lint or other debris blocking the speed sensor from reading the disc.
SOURCE: Running belt slips om treadmill Sports Art 1060
Either the belt has stretched (normal wear over time) or the tension needs to be readjusted to tighten it. Every treadmill is different, and some can't be adjusted, so I can't really help with particulars, but if you get down and look really carefully, you'll be able to find the tension adjustment mechanism if it exists. Good Luck.
SOURCE: i have a sports art 1180 treadmill that beeps err 7 how do i fix this thanx
ERR E-7 indicates that the DC incline motor and the variable resistor (VR) are not synchronized. Signal from the VR is not being received properly. Mechanical and/or electrical calibration is needed to reset this error message.
http://www.sportsartamerica.com/SAF/support/technicalsupport/techtips/Treadmills/DC_Incline_Calibration.pdf?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
