Cars & Trucks Logo
Charlene Roberts Posted on Dec 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doors will not open with the key that I have for the ignition. Any ideas?
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
  • Posted on Dec 20, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067007
Points
28436
Auto Repair : Power Door Lock Troubleshooting
sofia2013.com/auto-repair-power-door-lock-troubleshooting/
Jul 29, 2014 - can't use the key i have to go through the passenger door and unlock it ... when I get out of my 2003 Honda Accord, and leave the keys in the ignition, ... Any ideas why all the doors wont lock even pushing the lock button in the
Remote won't unlock passenger or rear doors - TDIClub Forums
https://forums.tdiclub.com/showthread.php?t=355194
Jun 4, 2014 - Will unlock the drivers side door and rear hatch (wagon). ... Any ideas, ... I have the VCDS and tried to program the remote with no success. ... precisely, but it was something like put the key in ignition, turn to acc, then push the unlock button. .... fiddling around with passenger door did not produce any result.
Door locked with key in ignition - TDIClub Forums
https://forums.tdiclub.com/showthread.php?t=125387
Dec 17, 2005 - Anybody have any ideas on this? I know there should ... The door willlock with the key in the ignition and the car running. It does automatically ...
Ignition key won't open door - 8th Generation Honda Civic Forum
www.8thcivic.com > ... > Mechanical Problems & Technical Chat
1helpful
2007 Yaris: Key reminder buzzer and auxiliary/accessory beeping not working
I reckon it can only be three things;
The door switch because it signals that the door is open. Does the interior light come on when you open the door?
The microswitch in the ignition lock that identifies there is a key in the lock.
Or it needs reprogramming by the dealership.
An 08 prius keyless entry doesn't work, changed the batteries, pushed the disable button and reset it, still no go. Any ideas?
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition and Pull key out twice (Do NOT Turn)
3. Perform these steps within 40 seconds.
A. Close then open the drivers door twice.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
B. Insert the key into ignition and leave it in ignition.
C. Close the drivers door.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
1helpful
My ford radio comes on when I open the door no key in ignition
Call Ford, it might be something that can be set to do that. Many cars have features that can be set up in that way. Other than that I have no idea? Good luck.
Warning chime
you have a broken contact in the ignition cylinder.insert a pick or a long thin nail in the hole right underneath ignition swith,keep it pressed and turn ignition to on(do not crank)then pull key and ignition tumbler out from cylinder.you will find a contact piece part of a plastic half ring and a wire which is broken,replace it ,ur problem solved.
Coding spare key for a Toyota Echo?
Adding key.
Note:
You must be having one working master key to perform this function.
1. Start with the key out of the ignition, drivers door is open all others closed and drivers door is unlocked.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode.
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock and then unlock once indicating successful programming. If the door locks cycle twice, repeat steps A and B in step 6 as the remote was not accepted.
3answers
Key will not turn in the ignition or door lock
did someone possibly switch your key with another one , or have any of the teeth on the key bent or broke off?
I need programming instructions for a 2002 toyota highlander for my remote.
not accepted.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
