Question about Samsung Galaxy Tab 2 7.0
Somehow I change the log in and how to access applications.
When I turned tablet on, I would always just have to swipe the screen and it would open up, and I could get it to page from screen to screen by just wiping the screen from either right to left or left to right and it would change pages, but I changed something by accident and now I have hit the application once and then I have to hit it twice to get it to open, and I can't go page to page by swiping the screen from right to left or left to right. How do I reset the tablet to the way it was originally?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
Browse the setup parameters, you should find the answer there (or in the manual...).
Posted on Dec 22, 2015
6ya staff
SOURCE:
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
How do i turn off the text to speech feature? It has been accidentally turn ed on 3 times. can't get to settings to turn off.
Step 1
Swipe the Status bar at the top of the screen towards the bottom of the screen to display the Quick Settings menu, and then tap "More." To open the Quick Settings menu in Explore by Touch mode, use two fingers to swipe down the Status bar.
Step 2
Tap "Accessibility" to view all settings related to accessibility. Locate the Text-to-Speech and Voice Guide options in the menu.
Step 3
Turn off the "Text-to-Speech" and "Voice Guide" options to disable the voice capabilities of your Kindle Fire HD.
Jul 29, 2015 | Amazon Kindle Fire HD 8.9"
Last Gmail I looked at is locked on screen on right side.
Close GMail first by swiping it off the running apps screen.
Uninstall GMail using the *Uninstall* option in:
Settings > Apps > Downloaded > GMail. Touch GMail and you will get another screen with an option to uninstall it. Touch the uninstall button and it will uninstall.
Then go to the Google App Store and download it again. It sounds like the Mail app got corrupted somehow.
May 11, 2015 | Tablets & eReaders
I was looking at my 9' tagital tablet this morning and swiped the screen and it went blank. I know it is on because when I swipe on it, it is making sounds. This was a second hand purchase, no manual.
Hi Debbie. Try holding the power button in for about 30 seconds to force the tablet to power down and then turn it back on. It may be locked up on an application this may reset the tablet.
Apr 28, 2015 | Tagital Tablets & eReaders
My ipad mini is on but when i try to swipe the screen to unlock it it does not open. what can i do ?
turn it off and see if the slide OFF can be swiped
If NOT... the screen could be damaged
Mar 10, 2015 | Apple iPad Tablets & eReaders
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
I can not connect to face book from my home screen on my iPad. Yet I can connect through safari. I'm thinking it is something in my settings
Just a thought as I just experienced this myself: I wasn't aware that the applications on my ipad run in the background. So when I tried repeatedly to connect - each attempt was opening a new log in to Facebook. Once I learned that I had a number of background apps running - multiple times, specifically about nine Facebook entrances - I closed them all and was able to log in immediately. I'm not sure how something very simple (turning all these apps OFF - slipped by me.) If you wish to check: double click on your top / screen side, power button. Running apps will either have a red 'X' - older ipads, or have a 'mini screen' (each for all open apps) that you can 'swipe' off. On mine it's "up". This may not be what is causing you trouble but it was an instant 'fix' for me. Hope it helps - let us know? Thanks & good luck.
Nov 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do I fix this: Apps were downloaded but Icons don't show and I can't open them?
Pull a downward one finger swipe on the springboard to initiate spotlight. Type the application name to see if the global prefs log has recorded that you have the application installed with a valid owner code signature.
if applications were installed with another appleID and require an update to execute but you are signed into the AppStore with a different appleID, the situation you are describing can occur.
Aug 04, 2014 | Apple iPad Tablets & eReaders
Screen rotation lock is now audio muting. i want to return to screen rotation lock
Unfortunately, this is a new feature from a past update. There is no current way to change the lock button back. However, you can access the screen rotation lock by double clicking home, swiping right, and toggle the screen rotation lock. As a future note, in the next update, you will be able to change it back.
Feb 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Samsung Galaxy Tab 2 7.0 Logo
62 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
