Music Logo
Senou Lynn Posted on Dec 20, 2015
How do I fix the White noise when I plug anything into the input?
So I have a Fender 65 DSP amplifier. Every time I plug any cord into the input, major white noise comes out. This happens even when the cord is un-attached. Also, sound will still come out of the speakers if I plug a guitar into it. This isn't the typical white noise that amplifiers usually make, this is loud noise that can drown out the sound of anything else coming through the speaker. I tried plugging in headphones to see if it was the speaker but the white noise persists. Is it a defective jack? Something internal? Is this something I can fix myself?
Doug Caskenette
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 25 Answers
  • Posted on Sep 27, 2019
Doug Caskenette
Contributor
Level 1:
Greenhorn:
Night Owl:
Answers
25
Questions
Helped
13467
Points
77
Clean your control pots on your amp with spray cleaner. i forget the name but phone a music store and they should know or may even have some
Hamidreza salehi moghadam
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 22, 2019
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
248
Points
First checkout your cable
if you still have problem , change you pickup
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Apr 13, 2009
SOURCE: amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Anonymous
  • 73 Answers
  • Posted on Jan 21, 2010
SOURCE: i have a line-6 spider 30 amp that started humming
output caps. dont beat up your amp. crazy
yostamplifier.com
Anonymous
  • Posted on May 11, 2010
SOURCE: Amp Problem with my Guitar
check to see if your cord is plugged into the instrument input and not another input such as a CD input as I have on My amp
Fred Yearian
  • 5603 Answers
  • Posted on Mar 25, 2011
SOURCE: I have a Frontman Fender 25R, it has a power, the
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 12, 2011
SOURCE: Last night I took it to a performance,. I plug in
Here you go:
http://elektrotanya.com/yamaha_stagepas_300.pdf/download.html
Scroll down to "Get manual" on the webpage and click to download. IGNORE other download links. This is a class D amplifier and the switching power supplies run directly off the power line so as a qualified technician I am sure you know to use an isolation transformer while working on this for personal safety. I am GOING to make an educated guess at the problem... The circuitry has a surge limiting precharge for the input power filter with a thermistor that when power is almost up and circuits are balanced the thermistor is shorted out by a relay so that the high currents can be handled... I suspect that the thermistor has gone bad... now that can be due to a short in the rectifier filter combination OR even a failure in the switching power supply or lastly, just a part failure of the thermistor. Using an isolation transformer, ALSO put a 100 watt incandescent lamp in serie with the power input cord to act as a resetable fuse and current limiter while working on this. Let me know how it goes...
Fender Frontman 212R
sounds like bad caps and maybe a failing output transistors. Use Deoxit contact cleaner too.
2answers
Can you please advise? My Fender Blues Deluxe re-issue 180W has a humming buzzing sound which is not clean. Yesterday I used it, was fine and turned it off. Today I have the buzzing problem.
Does it still have a hum/buzz when NOTHING is plugged into the INPUT? If so, you MAY have a tub going bad. If the noise is only there when you have your guitar/effects, etc. plugged in, then the problem is the guitar grounding or effects faulty...
FIRST: When the amp is "cool", UNPLUG THE AMP POWER CORD FROM THE WALL! ! ! ! Then CAREFULLY remove and reseat the tubes one at a time. Be sure to insert back into the socket correctly. You MAY just have a bit of corrosion on the tube "pins"....
SECOND:Don't plug anything into the amp, turn on and warm up. GENTLY tap one tube at a time with a WOODEN pencil. DO NOT USE anything metallic (like a screwdriver....) and be VERY gentle. If the noise increases or decreases, you probably have a tube going bad...
That's all I have. If this doesn't cure the issue, best take it to a repair shop . . . .
My fender fm 65 dsp amplifier squeals and feeds back every time i turn it on
Is it plugged into a guitar at the time? If so, it sounds like you're using a speaker cable instead of an instrument cable. There is a big difference. Look on the cable to make sure. If guitar is not plugged in would be a completely different diagnosis.
My 412Hot Rod Deville has terrible humming/white noise when distortion channel is on
It doesn't happen often but I suspect that the high gain input jack is defective. With nothing plugged into either input jack part of the signal is grounded and there should not be any noise. It might be that plus a noisy preamp tube. Try swapping the first two tubes to see if there is less noise. Carefully bang your fist or use an insulated tool's handle to hear if the noise changes. It might be an intermittent solder connection as well.
I just traded for a Fender Acoustasonic Jr. DSP. Everything is great except some humming noise when I plug a 1/4 inch instrument plug into the second/vocal channel. I don't know if it would do the same...
This probably an impedance problem. Do you have the manual. If not see if you can get it on line. You can then research the impedance of the input and see if you have a problem. Fender website in support area. Hope that helps. Let me know..
Fender acoustasonic junior crackling loudly and electronic buzz when touch volume knobs
noise problem with fender jr accoustatics is the poor aluminum sheet ground design that wraps around the body of the amp. it happens to me all the time because i kept on moving/carrying/dropping the amp every time we do church service. i am thinking of using an aluminum cable to wrap around outside the body.
Will a MP3/iPod/CD player play through a Fender Frontman 65 or 212 "Power In" input jack?
The power amp input jack takes "line level" input BUT is monaural (single channel). The output of an ipod is Stereo. Hence you would have to "mix" the two channels before connecting to the Fender. Mixing does NOT mean just tying the two channels together. A minimu thing would be a passive resistive mixer consisting of a resistor from each of the IPOD channels to the common point going to the input of the Fender. Remember if you plug into the Fender power amp input you DISCONNECT the preamp and other circuits and would ONLY hear the IPOD input.
My fender rumble 100 used to cut out, now it's
Suspect the input jacks. Wiggle them and see if you get anything. They get yanked sideways because the musicians don't loop their cord thru a handle and they get yanked sideways.
Also you can try spraying sparingly CRC226 into the switches and pots. You can get it at Home Depot in the electrical department.
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
