Question about Fender Music
When i turn on my b dec the display says fender loading host then switches to read b dec30 and it sticks no sound comes out what do i do?
I have a Fender Tube Amp that no sound comes out. If I wear headphones I can hear the guitar very faintly. Any help?
try turning up the the amps volume. You might need a higher frequency of sound for the amp to pick it up.
Jul 07, 2017 | Fender Music
Fender G-DEC junior won;t power up the lights don;t come on it has a thermal cutout on the 12VAC transformer it was open circuit i tried bypassing it with soldered jumper still does not power...
Try changing out the Pico fuse. Only 50cents from online West Florida Components. Buy a few. Mine went out twice. It is Item # F021. It is a .5amp (500 mA)fuse-green and looks like a resistor. Location on the circuit board is near the transformer and on back edge or board behind the 2 brown wires connecting to the board and to the side of the 4 diodes there. I left the bad fuse in place and soldered the new fuse to it's legs-a lot easier and does not damage the PCB.
Oct 03, 2011 | Fender G-DEC Junior Modeling Guitar...
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
ON my fender mustang II as I switch channels with my footswitch there' s a lag before the sound comes up
Possibly you are holding the switch down???... it MAY activate on the release of the switch. Try quick tap on switch.
I tried to find schematic to analyze this but could not find one.
Apr 06, 2011 | Fender Mustang II Guitar Combo Amplifier...
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Amp goes into protect mode as soon as switch is turned on. Pasport 250
There is a problem with the internal amp itself. These are extremely difficult to access. Contact Fender for a local authorized service center.
Dan
Mar 11, 2010 | Fender Passport Deluxe 500watt Sound...
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
My 72' telecaster deluxe ri is great. but after doing some killswitching (turning the volume off the neck pickup) and switching between the bridge and middle possition quite fast, now it sticks and i have...
Oops you may have to replace the switch, it sounds like you have worn it out. You may be able to find a replacement on e-bay at a decent price or at your local Fender Dealer.
Aug 21, 2009 | Music
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
313 people viewed this question
Top Fender Music Experts
Michial Gueffroy
rjivaro
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
