Health & Beauty Logo
Stacy Duarte Posted on Dec 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My husbands clippers won't cut - Health & Beauty
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 22, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063396
Points
28436
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
tip
Why You Shouldn't Swap Small Clipper Blades Between Dog Clippers
Although dog clippers manufacturers claim that their clipper blades are universal (fit other dog clippers), they work best on the dog clippers they were designed for.
The socket (clipper blade), the hinge assembly and blade drive assembly (dog clippers) vary from manufacturer to manufacturer. If you are using different brands of clipper blades on different brands of dog clippers, there will not be a perfect fit.
HINGE ASSEMBLY
The hinge assembly secures the clipper blade (via the blade socket) to the dog clippers.
If the hinge assembly is not regularly replaced, your clipper blades will start to rattle on your dog clippers. The ears on the clipper blade socket are constantly rubbing against the metal hinge assembly, which consequently causes wear on both the socket and hinge assembly. You must ensure that there is a snug fit between the clipper blade socket and the hinge assembly or the blade will eventually rattle.
On average, if a groomer is clipping 8 dogs a day, the hinge assembly will probably need replacing every 12 weeks.
When replacing the hinge assembly, make sure that the screws are secure because if they are too loose the clipper blade will not cut correctly or not at all.
It is not advisable to try to adjust the ears on the socket to enable the clipper blade to fit the hinge assembly, because you will risk breakage which will render the blade redundant until you get the socket replaced by a sharpening professional. The best person to adjust clipper blade sockets is an experienced clipper blade sharpener because he has the relevant tools and should the socket snap, he has spares.
BLADE DRIVE ASSEMBLY / BLADE LEVER
The plastic lever on the blade drive assembly locks into the cutting blade and drives it backwards and forwards.
Problems occur because the black plastic lever is constantly rubbing against the metal cutting blade; so consequently, the plastic will gradually wear away. Once the lever is worn, the cutting blade won't be driven side to side as much as it should.
If the blade drive assembly is not regularly replaced, the clipper blade will leave tram lines in the coat, pull at the hair, the dog clippers will sound noisier and the clipper blade will eventually, stop cutting.
On average, if a groomer is clipping 8 dogs a day, the blade drive assembly will probably need replacing every 6 - 8 weeks.
If your blade drive assembly is worn, your newly sharpened blades will not cut because the cutter blade is not being pushed along the whole width of the clipper blade (it is more noticeable on blades where the teeth are further apart - 3,4 5 & 7). If this is the case, we would strongly recommend that you replace your blade drive assembly.
on Feb 28, 2020 • Dogs
I have just had all the blades sharpened for my clippers but they won't cut my dog's fur. Never had a problem before. Can you please help?
It is common to that a Blade Sharpening Service return your blades just as blunt as before, or even worse.
I advise that you try a new Blade Sharpening Service; trying out only a couple blades to begin with.
I recommend a mobile/on-site sharpening service.
1helpful
It's not cutting anymore, my husband greased it and cleaned it but it's not cutting, barely grazes the top. how do I know if the blades are sharp anymore. we have only used it 2-3 times on our cocker...
If you have another clipper, you can test the blades out on them to see if your blades are sharp. As for the blades not cutting on your clipper it could be a couple things. Your blade drive could be worn and not allowing the cutter blade to travel far enough each way to make a clean cut. Another thing to check is that your blade latch is not broken. This is the black hook by the blade drive on the clipper. If the blade latch is broke, the blade won't stay tight up on the clipper. Thus the blade will act like it is dull.
2helpful
3answers
New clippers
what type of hair clipper are you looking for. mannyssharpening.com has very good warranty they fix what they sell
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
4helpful
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
12helpful
3answers
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
1helpful
4answers
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
