There isnt any descriptrion as to which burner the coloured orifices are assigned to
SOURCE: convert kenmore gas range to propane
You unscrew the orifices in the range and screw in the new ones. In the oven you adjust the hood around the bake orafice by screwing it down.
SOURCE: I have a Kenmore Elite
This problem could occur due to various reasons
1)spark module needs a constant replacement.If you haven't replace for a while its time for replacement.
2)Excessive dirt cause the burners to light hard.Clean the burners and the valve fully.
3)Use the hair dryer to dry the holes and clean it perfectly.
4)There will be a switch near the burner that needs to be replaced or wired properly.
5)Check for the burner valves.Give air pressure to clean it.
Since you say only one burner is causing problem dirt could be the main cause.Clean it and let it dry for some time.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: kenmore gas range model 362.75508990 the burners
Greetings,
Do you here clicking from ignition system ? If no then Your ignition module( Small box located behind control pane) is gone.This is very common problem .$68 at Sears Parts direct.
SOURCE: Kenmore Electric Range Model #911 9237313-All burners quit at once?
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Testimonial: "This did not fix the problem but easily could have been the reason my burners wouldn't work. I appreciate the suggestion."
