SOURCE: I need help finding my password for my iPad 2
I take it you are talking about your login password for the app store if you go to https://iforgot.apple.com/cgi-bin/WebObjects/DSiForgot.woa/wa/iforgot and enter the information you should be able to get a new password. Hope this helps.
SOURCE: how do i set up ipad
To set password, tap settings,tap general,tap passcode lock.Enter 4 digit code,enter again for settings.Tap turn passcode on, then set reguired time and choose whether to erase data after 10 failed attempts.This feature can be left off if you wish.
Please Rate.
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
SOURCE: how to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
SOURCE: How do we log into a different person's fb account on this iPad?
it may be like a phone once you have set up an account to sign into it automatically stores that 1, so u would need to set up another log in account manually & then when u attempt to log in it will ask which 1 u want, if you cant set up more than 1 account, then u have to manually delete yours & then use his.
