My 19" Element TV shows message "Sorry for your inconvenience..This channel will return shortly.
TV in my spare bedroom, hadn't been used in about a month or longer. The remote never works like it should. I will never purchase another "Element" brand in any item that bears this name.I can't get any channel, only the message above. I have it unplugged now, hoping that this will resolve the problem. Unless someone else can provide a solution. I have done reset, unplugged for a few minutes, checked for code, nothing i have tried has worked.
Re: My 19" Element TV shows message "Sorry for your...
Element Electronics tv error codes Questions & Answers ...
www.fixya.com > Forum > Tags > tv error codes
Element Electronics tv error codes related problems. ... I need help programing mycraig 19 in flat screen tv with my universal remote control model TVG1307, can someone help ... I need the code to program the remote so i can operate my tv.
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
this is a vid im attaching to my email to custamer support to try and fix my ... Show more ... Element HD TV unboxing and review, buyer beware!
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
See if another set works there to make sure that the cable is providing signal. If it is then the tuner on set is fubar - you can always get an external tuner and plug it into your set's audio/video input or HDMI or whatever you got.
you will receive upwards to 150 channels (depends on how the tv is designed) you will not receive all the channels which you receive on the tv which has the "box". You will need an addtional box if you want to receive essentially any 200 or above channel.
Hope this helps
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
