there is always a very tiny hole that fits a sewing needle or paper clip, at the back or around the sides. its the rest button which returns it back to factory default settings. on the tablet i'm looking at, its halway down one of the longest sides.
There should be a small hole to stick a paper clip into to do a reset,press it gently til it reboots
Alos can do it following this advice
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Factory Reset: go to Settings from the home screen. Click on "Privacy" and then click on "Factory Data Reset." Go through the data reset process. This will remove all personal data from the device.
Or
Shutdown the tab, enter the recovery console by holding both the return button and the power button until you see the android icon with a triangle. Press return button again and recovery menu will appear. Navigate through the recovery menu using vol up/vol dn or home and menu buttons on the tablet. Select "wipe data/factory reset." and then "reboot system now"
