Question about LG WM Washing Machines
WF-760 FUZZY LOGIC 7KG machine, Problem is, some washing powders remain in the cloths and not properly washing. earlier it works well.
    President:
  • 842 Answers
More often than not, this is a problem with a faulty heater in the machine not getting it up to temperatre (which help the powder dissolve). Put it on a 90 degree wash and keep checking the temperature, if it's not getting hot, then you need to swap out the heater. Ift IS getting hot, then it could be an empty pump problem. If the pump or waste pipe are blocked, the wash will take a very long time but it will be struggling to evacuate water and add fresh, which will also causse powder residue to be left behind. But I'd put my money on a heater fault
Posted on Dec 26, 2015
Anonymous
SOURCE:
Lg fuzzy logic 7.kg turbo drum top loader model wf-t7051td does not agitate or spin properly
I would call the washing machine engineer for a quote as there are to many things that can go wrong eric
Jan 11, 2018 | LG Washing Machines
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Apr 16, 2015 | LG Washing Machines
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
115 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
