Watches Logo
r
rolando gonzalez Posted on Dec 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant set the arm time - Watches
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 26, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061689
Points
28436
[PDF]The Apple Watch User Guide (PDF)
https://manuals.info.apple.com/.../apple_watch_user_guide.pd...
Apple Inc.If you have difficulty seeing the Apple Watch or iPhone screen to set it up, .... Note: If you disable your passcode, you can't use Apple Pay on Apple Watch. ..... Alarm • Timer • Stopwatch • Battery charge • World Clock • Your monogram (displays ...
[PDF]Cal. 7T62 - Seiko
www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
SeikoYou are now the proud owner of a SEIKO Analogue Quartz Watch Cal. .... into consideration the time required to set the ALARM hands and to adjust the .... The single-time alarm cannot be set for a time more than 12 hours ahead of the current ...
How to Set an Alarm on the Apple Watch - YouTube
I cant get the arms to automatically set themselves
About Self-Winding Automatic Watches - Self-Defense Armory
www.selfdefensearmory.com/aboutautomatics.html
about mechanical watches, self-winding, automatic watches. ... Secondly, and this is where it gets a little hazier, people buy automatics for reasons that cannot be clearly ... Self-winding automatic watches depend on the movement of the arm to ... Avoidsetting the day and/or date (if your watch has these functions) at night.
About watch movements: technical details
I'm not sure about this arm movement.
if the watch as not been worn for a long time it's best to wind it by hand first to get it started, just make sure the winder is pushed all the way in and then just keep winding it clockwise till it start going..
1helpful
Hello I have a movado 800 series sub 200 and
it is probably either in set time mode, or some sort of chronograph mode. play with the buttons.
I have a new invicta watch model number 6089 that I just recived yesterday. I can set the time and date but for some reason I can not set the 3 arm?? I have read the instructions and still it will not...
The trick to setting the 24hr hand on the 6089 is to pull the crown out only one notch (not two) before using the upper push button to change the time. As it's a 24hr hand, the best time to set it is at the top of the hour.
4helpful
Sport tag h cant set time
The crown is lock that's why you cant pull the crown to set.The crown has a thread that lock, you must winding it clockwise to unthread it, so you can set the time..
Regards:
VOTIT
Dont forget to rate:
How do i set the time on an Invicta Lupah mens watch with three subdials
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
1helpful
Have an Invicta Lefty Quartz Chronograph. The subdial that marks the minutes fails to reset to 60, though the large second-hand resets perfectly. Recently I bought another Lefty and had the same problem. I...
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
