Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab Logo
D
Deanna Gschwind Posted on Dec 27, 2015
How do i re-load google playstore on my tablet
Model GT-P5113TS
I'm trying to reinstall a game on my Acer tablet my daughter did something and she can't remember but it's coming up with failed to extract resources needed b112cpp
it appears the google services app may need resetting (android settings > app manager > google services > clear data) this will reset the tablet's memory of whats installed until the playstore app is opened again if it fails let me know
How do I get my email on new tablet?
android > settings > accounts > add account or use the gmail app from the google playstore
The playstore on my tablet do not want to open sins i did the software upgrade
In order for your tablet to have a working Playstore, it must be compatible with Playstore.
The reason that I? telling you this is because a lot of people buy a used tablet, with third party software in which force a Google app into the tablet.
Since there is no detail about the tablet, I can only guess.
Go to settings>app. From here search for Google Services, if there is none, then it means that you must install it for your device or update it. If there is none for your device, then it means that your device does not support Playstore.
1helpful
Can't sign in to google playstore.
Hi there joe i want you first of all to check your internet connection if it is connected please check the storage or if the playstore is restricted in your country if not try uninstalling then re installing or just try the app if you didn't install it yet or do contact thier support center i hope this answer was helpful
4answers
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
How can I install playstore on my Tablet
Your tablet is more likely a chinese no name one.
You can download the Play Store standalone version from here:
APK 12 FEB 2015 Google Play Store v5 2 13 Newest version unmodded
My google play store has stopped how can i put it back on
What's the error? Just go to settings, apps, search for PlayStore and tap clear cage and clear data. Do the same thing with Google Play Services. Open the PlayStore app and follow the instructions.
How do I install google play store.
Make sure by going to the Application Manager under Settings and verify that you haven't just lost the icon on some page. The playstore is normally loaded as part of the operating system for your device. There are places where you can download an installable file for the playstore, but some devices will not allow installation of downloaded .apk files, or require you to turn off a setting that prohibits installing downloaded files. Without knowing the mfr and model number of your device, who knows what you would have to do to get this app reinstalled if you truly have somehow deleted it.
Google Play Store 5 0 38 APK Download APKMirror
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
