How do I stop continually trying to connect to wifi and failing
LGL34C Android 4.4 used to connect to home wifi. My other devices connect to wifi. Wifi toggle is neither on [blue] or off [dark gray]. When touch it says "turning wifi on..." for 3 days now. I cannot turn it off...... Took battery out for 15 mins and when it restarted, problem was fixed!!!
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Go to your setup setting and check your wifi setup might have change because it not storing the setting might have a problem with the tablet would replace if under warranty
Recovery mode
If you've never synced your device with iTunes, or haven't set up Find My iPhone, you'll need to put your device in recovery mode. Then you'll restore your device as new or from a backup.
This will erase the device and its passcode.
1.Disconnect all cables from your device.
2.Hold down the Sleep/Wake button, then "slide to power off" to turn off your device.
3.Press and hold the Home button and plug the device into your computer. If your device doesn't turn on automatically, turn it on. Don't release the Home button.
4.Continue holding the Home button until you see the Connect to iTunes screen.
5.If iTunes doesn't open automatically, open it. iTunes will alert you that it has detected a device in recovery mode.
6.Click OK. Then restore the device.
If your device doesn't go into recovery mode, try steps 1-4 again.
I hope this helps
It could be because of the amount of devices that are connected to your wifi. Too many devices could put a lot of weight on your bandwith causing the wifi itsself to become slower. Disconnect any devices using wifi in your home that dont need to be on every day and try reseting your modem or router. You could also use a usb cord to get a more direct connection or you might have to upgrade to a faster wifi company. If the problem still continues take your device back and get it fixed, call the number in the troubleshooting guide, or visit the nextbook website and make sure you have your device registered.
I had this problem with my son's Kurio over Christmas and found that connecting to wireless in Kurio mode was impossible. If you go to the parental mode and click the switch to Android button there are settings for the wifi in the Android platform settings. You can set up there and then go back to the Kurio safe mode for the children to use. Hope this helps...
Something has changed in your wifi settings first check wifi is turned on (press menu On the right hand side next to the battery it will say off is wifi is turned off) the first option in the menu is turn on wifi. if wifi is on click home -> menue and go to settings scroll down to wifi see if your wireless network is there if it is not but other networks are there it is a problem with your house network not the kindle
if your house network is there with a message next to it saying connect then click connect if it says forget then forget it and connect again.
If the device fails to connect you should go into settings push menu and then restart if still no luck go to settings and click reset to factory defaults and try again through wifi settings if this does not work their is a fault with your device and you have to talk to amazon
amazon will charge you to replace the device if you tell them anything like you dropped it so as far as you know it was working when you went to bed you woke up the next day and it didn't work ;)
