I power up the m1600, but I am using a 1000VA voltage converter because I am in Europe. I'm getting no signal and I am following the instructions as far as what button to push to see or hear signal. Only the power light comes on and if I push any solo button the solo indicator light comes on. I have been trying to run XLR, 1/4 line, 1/4 line from ipad, direct line in from roland synth module ...and nothing. I need help
As long as your power supply is supplying the correct voltage and the amp rating is sufficent, and of course the power supply itself is functioning, then your problem is more likely to be a routing error somewhere.. it's probavbly best to center all controls, disengage all switches, and start over from nothing. You should also check that what ever you are using to hear the signal is functioning correctly as well.
