Emerson LC320EM8 32 in. LCD TV Logo
H
Henrietta Spears Posted on Dec 28, 2015
How do I connect Apple TV to my TV
I only see one port in back of tv and my cable box is in that one
My Pyle PT694BT receiver plays video, but plays static when connected to Apple TV 4K.
There are a few possible reasons why your Pyle PT694BT receiver is playing static when connected to your Apple TV 4K. Here are some troubleshooting steps you can take:
  1. Check the cables: Make sure that all the cables are properly connected and in good condition. Sometimes, a loose or damaged cable can cause static or no signal.
  2. Check the settings: Ensure that the settings on your receiver are configured to accept the correct input from your Apple TV 4K. Check the user manual of your receiver for specific instructions.
  3. Update the firmware: If your receiver has outdated firmware, it may not be compatible with your Apple TV 4K. Check the Pyle website for firmware updates and follow the instructions carefully to install the latest version.
  4. Try a different HDMI port: Sometimes, the HDMI port you are using on your receiver may be faulty. Try connecting your Apple TV 4K to a different HDMI port on your receiver to see if that resolves the issue.
  5. Test with a different device: If the problem persists, try connecting a different device to your receiver using the same cable and HDMI port to see if the issue is with your Apple TV 4K or your receiver.
2answers
I am a new customer t o Netflix. I joined yesterday and got number. I am on the net at home and have Apple TV. How to I start watching Netflix on Apple TV?
Connect the Apple box to the TV with a cable. Using the TV remote select the input port you connected the apple box to. ie HDMI.
Click the center button on your apple remote. You should see a Netflix icon. Select it and then log in to your Netflix account
TV box is not working wend Is connected to HDMI switch.
CONNECT IT AGAIN TO HDMI INPUT AND CHANGE SOURCE ON THE TV SETTINGS INPUT SHOULD BE HDMI1
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
2helpful
How do i connect my cable box to my tv
Connect the coaxial "Cable In" cable to the "Cable In" port on the back of your TV cable receiver box. Make sure your receiver box is not plugged in yet. 2 Take the TV audio/visual cable, and connect the red, blue and green ends to the corresponding color "Cable Out" ports on the back of your cable receiver.3 Take the other ends and plug them in to the red, blue and green ports under "V1" on the back of your TV.4 Take the audio cord with the red and white ends, and connect them to the corresponding color ports of "Audio Out" on the back of your cable receiver; then, connect the other ends to the corresponding color "Audio In" ports on the back of your TV.5 Turn on the power of your TV cable receiver box first. Allow it to run through the boot sequence. When you see the time appear on the front of the cable box, you may turn on the television and check your signal.
  • 1helpful
    Hdcp error mesage when connected to my freeview hd box.
    What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
    This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
    The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
    The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
    The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
    How do I connect a JVC DVD video player model XV-S302SL to a cable box and a TV
    There are several ways in which you can do this.
    The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
    That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
    Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
    Hope this Helped Clarify things for you.
    If this has then please leave a thumbs up
    Cheers Little Dish Fitter.
    2helpful
    Need help hooking up TV, BluRay, Home Theatre & cable box
    I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
    So here are the components and the cable types used to connect:
    1. HD Cable Box to TV: HDMI cable & Optical Audio cable
    2. Home Theatre to TV: Red, Blue & Green component cables
    3. BluRay Player to TV: HDMI cable
    I hope this helps someone else.
    Top Emerson Televison & Video Experts
    matt martin
    matt martin
     Grubhead
    Grubhead
    Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
