what lamptop, none stated, nor the OS running on it. windows?
contact the maker of such device.
it uses a USB, connection.
and a Smartphone
with
Requires: Android 4.4 and up
i dont see PC support, i googled for you, see nada
mate.If the motor was rebuilt and maybe the prop had a new bush put in it,it could be the wrong spline was put in the prop hub.Or wrong diameter.Without more info,this is a guess.hope this helps
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
do u use internet...
it might b because of start programs..
try to disable some startup programs which are unnecessary..
and u neeed to use disk cleanup utility and defragmentation...
most probably you have not switch on the wireless mode. make sure you have wireless mode ON. than it will ask you for network code. than you can enter the code. or also make sure you are putting sim card in correct direction.
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
