Sony STR-D790 Logo
e
ed packett Posted on Dec 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No display can you help
Display went out comes on when you push on it
Steve K
Level 3:
Genius:
  • Sony Master 1,054 Answers
  • Posted on Dec 30, 2015
Steve K
Sony Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
573859
Points
2865
If the display turns on when you push on the front panel, then you most likely have bad solder connections on the display tube. These will need to be re-soldered.
Sauna does not come on when I push the activation button. Instead the display shows OH.
Sounds like you have a temperature sensor that went bad, look for the model number and find a manual for it or call the manufacture and exsplain your issue.
Oct 27, 2017 • Pool & Spa
1helpful
My sony str de 835 display went out. sometimes
Most likly bad solder connections on the display board. Look for solder rings on the LCD. You must remove the front panel to gain access.
Parrot CK3100 cutting out/Blank
try pushing the wire into the display, this commonly comes loose.
3helpful
Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
2helpful
I had to unplug my cable/tv last night and when I turned it on this morning I could not get the menu to display the cable accept on the menu screen. I went in to turn off the home theater and the cable...
Push the menu button and enter 1370 and push enter and the tv picture will appear on the screen. If it does not push the input button until the picture appears.
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
4answers
Electric, dome lights, dash display, radio
Yes, probably it's a fuse.
Try to remove the fuses one by one and check if there is a broken one and replace it.
KENMORE ELITE PROBLEM
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
