Tablets & eReaders Logo
Roger Bonds Posted on Dec 29, 2015
Manual, setup Can't connect to internet?
Unable to get internet
You can separate the troubleshooting into parts. Go to a place having a wi-fi internet hot-spot, like Starbucks or Gloria Jeans'. Assuming you are in the USA:
http://www.wififreespot.com/
Get a coffee and turn your tablet wi-fi on. From
http://www.manualslib.com/manual/742236/Rca-Rct6272w23.html?page=11#manual
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it. Tap 'Agree to conditions' if necessary.
You should then be able to go to a webpage. Once you get this bit working, you can turn to your home internet.
You need of course an account with an ISP, who will probably supply you with a gateway (modem/router). If you only have a modem (connection box to the ISP) that does not have a wi-fi capability, you will need to get a router (wi-fi broadcaster). These can be quite small and neat.
http://phandroid.s3.amazonaws.com/wp-content/uploads/2015/10/OnHub-by-ASUS-Screen-Shot-2015-10-27-at-5.29.02-PM.png
For assistance on this contact your ISP tech help line, since some of the advice is peculiar to the equipment they use.
Connect the router (if you needed to get one) to the modem with an ethernet cable
http://cdn2.pcadvisor.co.uk/cmsdata/features/3502678/ethernet-cable.jpg
and follow the setup instructions that came with it. Then do the same as in the cafe wi-fi hot spot. It should work.
Have internet signal but can't connect.
internet routers have several protocols that they can use to connect with other devices (wifi) the most popular is WPS there are others , both devices to be mated in wifi HAVE to be on the same protocol , otherwise they ignore one another
ck your router and tablets wifi device setup tables to see what one your using , as they must match
I have a trio stealth i need a password for wifi
You must have a wireless router, connected to the internet. then you have to setup the router and the wireless connection. Don't forget to setup a password protected connection with WEP2, or else someone else can use your connection and consume your data plan.
How do I set up an internet connection on my nextbook using an existing accoung?
Unless you have a network cable plugged in that is the only way it will work.
HOW CAN I GET PROLINE TABLET R718DC-R TO FUNCTION ?????
After setting data and time you are not ready. You still have to install lots of apps, but first you should setup a (wireless) internet connection to your wireless router. If you don't own an wireless router and you don't have an internet conniption in your house, these things you have to install first.
While installing, setup a security login and write down the settings and password for your connection. You need that to connect your tablet.
Success
Amazon kindle registration
Just a few questions.
is your computer connected to the internet with a wireless connection, or with a cable? Is the internet connection you see on the kindle, the name of your wireless router? Did you setup the wireless connection on your kindle, using your connection name (the name you gave in on the wireless router you own) and password.
If you answered one or more of these questions with a no, first solve or change that. When you don't have the answer, because you don't know, you have to asume it is a no.
please tell us you did setup the wireless connection correct, so I can look to other possibilities.
Tablet instructions
You can find the instructions for how to setup your secure wireless connection in the Huawei manual. And in the little booklet that came with your Samsung you can read how to connect to Huawei.
don't forget to make a note about the name and password you gave in on the Huawei.
please don' ask me to type over these pages, because one way or the other, you have to read it. Better take the booklets.
My tablet is not connected to internet. how can i fix the problem?
You need to contact your cell phone service provider and check out their various Internet and phone plans then select one that suits your requirements.
They will provide you with connection and setup instructions.
E-mail problems
Hi. Please make sure that you are connected to the Internet either through wireless or 3G. Browse or search google first to make sure you have Internet connection then setup your email.
Also, double-check your server address and account info. One missing character will cause you delay.
My new tablet will not connect to internet. i have the usb plugged into mt laptop. i do not have a wireless router?
open network connections on your laptop and select both the wireless adapter AND the internet connection adapter in there and right click on them and click bridge connections. Then go into the network setup wizard (XP) or network and sharing center and click connect to a network and choose adhoc connection. then open wireless settings on the coby kyros and connect to the adhoc connection on your laptop. You should then be able to connect to the internet on it
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
