You need to check your inputs. Make sure your tv is set to the same input that you are plugged into. Ex. If you are plugged into HDMI 1 then your TV SOURCE needs to be on HDMI 1.
There could be several reasons why your Vizio TV goes black after being turned on, including a malfunctioning power supply, a damaged display panel, or a faulty backlight. Here are some steps you can take to troubleshoot the problem:
Check the power supply: Make sure that the TV is properly plugged in and that the power outlet is working. You may also want to try plugging the TV into a different outlet to see if that solves the problem.
Check the display panel: If the TV is getting power but there is no picture, the display panel may be damaged. Look for cracks or other signs of physical damage to the screen. If you find any damage, you may need to replace the display panel.
Check the backlight: The backlight is responsible for illuminating the screen, and if it is faulty, you may experience the symptoms you described. Look for any signs of damage to the backlight, such as flickering or uneven lighting. If the backlight is the problem, you may need to replace it.
Reset the TV: Sometimes resetting the TV to its default settings can solve the problem. To do this, unplug the TV from the power source, wait a few minutes, and then plug it back in.
Contact Vizio customer support: If none of these steps solve the problem, you may want to contact Vizio customer support for further assistance. They may be able to provide additional troubleshooting steps or help you arrange for repairs.
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Its probably damaged the board that powers the backlight in the surge. Repairs on this depending on the size of the TV might out way the cost of replacement. I
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Tv turn on now,have a flashes a picture only a few sec.than dies and have sound left only?Yes,than those 2 long boards to the left and to the right call the LCD inverter boards are dead.These 2 long LCD inverter boards,job are to help the LCD screen panel to have a backlight to produce a pictrue.Tries websites like Shopjimmy.com.Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
