Well you can try to ask for the combination from the store where you bought the item. hope they have the combination
The combination lock is one opened not by a key but by the alignment of its interior parts in a definite position. The most common types have an internal mechanism consisting of a series of three or four interconnected rings or discs that are attached to and turned by a central shaft. Manually rotating the outside knob or dial turns the discs, each of which is "programmed" to stop at a notched opening or gate. However, with a four-disc lock, certain preliminary spinning of the dial is necessary to get the lock to move the correct disc. The knob must first be turned to the right and spun past the first number four times before being allowed to stop beneath the marker. Next, rotating in the opposite direction, the knob must pass the second number three times. Reversing directions again, the user must spin the dial past the third number twice, and so on. When the apertures of all the rings align, they enable projections on a spring-loaded bolt to slide through, releasing the bolt and opening the lock.
thanks.keep updated.
I know how the combination works I need to have the combination to this safe. How do I get that and from whom.
I need to know how to get the combination for my brinks 5059.
