Question about Sony DVP-SR200P DVD Player
How to set up remote control so it will work volume and power on my philips tv the sony player i have is a dvp.sr200p
    Sergeant:
  • 236 Answers
Why not use the Phillips remote to control the DVD instead of the reverse?
The Sony codes are listed below.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
Posted on Apr 25, 2016
6ya staff
SOURCE:
njvinod
Vinod Kumar
  • 1462 Answers
SOURCE: Hi, I need to unlock
THere was some problem, with the chat...I was not gettin gyour messages
1.Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Posted on Sep 19, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: I purchased dvds from ebay and they will not play
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
Posted on Apr 14, 2010
Anonymous
SOURCE: How to turn off the closed captions on my sony dvd
I had the same problem so i simply turned off the CCD on the tv itself and no more captions!
Posted on Jun 12, 2010
Mr Solutions
  • 129 Answers
SOURCE: cd compartment wont open and it is locked dvp
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Posted on Jul 26, 2010
tejascwboy
SOURCE: Sony remote RM-DX500 not working with Disc
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
Posted on Dec 24, 2010
Universal remote code for Sony dvp-sr200p using a rca remote
Use code search to find something hat handles some or all functions of your Sony DVD player. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Feb 19, 2017 | Sony DVP-SR200P DVD Player
Need to no how to make my Sony DVD player remote work the volume and power on my Philips TV
Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes.
11454, 11054, 10690.
Jan 01, 2016 | Sony DVP-SR200P DVD Player
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
Program rav322 wg64630 to sony dvp-SR200P
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.
Feb 14, 2015 | Yamaha RAV322 Remote Control WG646300
I just bought a sony dvd player model # DVD-SR200P and it has power and it counts on the dvd player but it wont show on any of my TV's?????????
check the connection from dvd to tv. check if you select the correct input settings on you tv... if the connection is ok and the problem is not solve, just bring it back to the store... ty
Jun 23, 2011 | Sony DVP-SR200P DVD Player
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
Nov 03, 2010 | Sony DVP-SR200P DVD Player
What is the code to control a polroid model 1511 lcd tv with a sony dvd remote?
There is no code for polaroid tv. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control
Oct 17, 2010 | Sony DVP-SR200P DVD Player
How do i program the remote for my DVP-sr200p/o dvd player to my tv
Is there a switch on the top of the remote for tv? Switch it to tv and consult the Sony manual for programming to your tv. Or esupport.sony.com
Aug 09, 2010 | Sony Televison & Video
Sony DVP-SR200P DVD Player Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
