RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet Android 4.1, LCD Touchscreen, 800x480, 4 Hours Logo
T
Tina Chapman Posted on Jan 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an RCA RTC6672W23. It will not charge. I have tried factory reset {Power button and Volume button at same time} the device will not do anything at all
Danny Kuhlmann
Level 3:
  • RCA Master 1,443 Answers
  • Posted on Jan 02, 2016
Danny Kuhlmann
RCA Master
Level 3:
Answers
1443
Questions
Helped
262333
Points
4794
Either your charging cord or the battery or connector for the battery is bad
1helpful
PLEASE I USE IRULU BUT I WAS TRYING TO REINSTALL IT BE IT WENT OFF NOW HAVE CHARGE THE PAD BUT HARD TO REINSTALL PLEASE HELP.
You need to fully charge the tablet and THEN do a factory reset. The hardest part is waiting.
Follow the steps provided below to perform a Hard Reset on your iRULU Android Tablet:
  1. Turn your iRULU tablet off.
  2. Press and hold the correct key combinationto boot your Android tablet into Recovery Mode.combinations, which include:
  • Home button + Volume Down button + Power button
  • Power button + Volume Down button
  • Power button + Home button + Volume Up button
  • Power button + Volume Up button
  • Power button + Volume Up button + Volume Down button
  1. Release the power buttons once your screen turns on, and the device vibrates. Keep holding the other buttons for 10 seconds.
  2. Your Tablet should now boot into Recovery Mode.
  3. Scroll down to the 'Factory Reset' option using the volume down key.
  4. Select the 'Factory reset' option by pressing the power button.
  5. Now your Tablet will start the hard resetting process.
Once the process begins DO NOT press any buttons and don't try to turn the device off.
Your tablet should now be reset.
I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
Tablet will not come on
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Tablet will not charge or turn on
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. if this doesn't work your charging port may be lossened or damaged, have a technician check it.
RCA 7 inch table says no command
Troubleshoot
You may have to reset it. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. (make sure it is fully charged before you do the reset.
Won't charge
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. if this doesn't work, your charging port might be loose or damaged. if the reset doesn't work, have a technician check it.
Wont finish its loading process
It goes to the rca loding logo and keeps loadin until dead
do you have the correct charger, because if it doesn't and you are charging using usb, it may not be charging it enough, if you have the correct charger You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Reset rca tablet
You can perform a hard reset on your tablet 2 ways. The first is by going into Settings>backup and reset and choosing the Factory Data Reset option.
If you are stuck at the startup screen or a password/pattern screen and cannot boot into the system, you will need to use method 2, which is booting into recovery mode. Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
Top RCA Tablets & eReaders Experts
 Mikey
Mikey
k24674
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
