After memory clear on Ricoh Mpc7500. Colour document appears double.i have run force line position with sp2111 still no positive result. unlike other mpc where you have a, b and c to execute but on mpc7500 there is no option for a, b and c. Any idea pls
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
SOURCE: prints streaks of lines with fussy & unclear colur
Yes cleaning the LED heads do make a difference. If they are even the slightest bit dirty your output will be affected. However the quality of the prints on these printers are not very good. I have 3 of them and all of the product subpar quality (right out of the box) especially with lighter solid background colors.
On card stock (especially coated card stock) you'll notice shading on the entire page. Again this happened out of the box on all three of my printers. I researched this and read that it was an effect of the LED technology.
Also if you look closely at your prints you'll notice that there are bars in your print. These bars look like there could be something wrong with the LED matrix...
I just installed a magicolor 7450 II and man what a difference. No shading, perfect picture quality, and larger banner printing (12" x 47") Of course the price tag is a lot more ($3k)
SOURCE: Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
SOURCE: I have a ricoh mpc 3500, it works fine but i am
Hello sir; There are two way to get rip off the lines,# 1 , aat the end of the transfer belt there have a cleaning unit , clean up , if need to replace cleaning blade , change it. #2 , after you copy , pull out each drum unit check it out see which drum with the line on it, replace that drum unit.
SOURCE: Ricoh 3800 printing dots on the page
sounds to me like there is damage to the charge roller in the black pcu. these can be dissasembled and the charge roller inspected/cleaned but the blk drum units are inexpensive enough its probally just better to replace it
