The unit still works, but some of the buttons no longer respond. Spin, off, water temp, and a few others don't work.
SOURCE: Washer options not working on control panel.
when you push the button to select the options that arent working do the lights at the selected option come on? if they do not then you need a new control panel they will cost you approx 100$ to sell it as is you would be lucky to get rid of it, they only last for 7 or eight years max anyway before the outer tub bearing fails.
SOURCE: my MLE2000 washer will start to spin and then
Check the resistor on the control board at position R11 and see if it's black from being burned out. If so get back to me, Mark the neptune Pro
SOURCE: Maytag MAH4000AWW no longer does
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MAH4000AWW/3048/0153200/M0603006/00013?blt=06&prst=0&shdMod=MAH4000AWW
It could be the motor control board not telling the motor to switch to its highest speed, but it could also be control board not telling the motor control board to activate, but it could also be in the timing circuit. What other indications are you getting? Take a look at the wiring diagrams for this machine on the referenced site.
