Hotpoint Ultima WT960P Washer Front Loading, 7 kg., "A" Energy Rating Logo
B
Beverley Davies Posted on Jan 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does error message F-10 mean
Error message F-10 comes up on display
Carmen Mikulic
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Jan 04, 2016
Carmen Mikulic
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
217594
Points
909
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
What does hi, 'upper thread inserted' mean?
Try contacting your Bernina dealer. They should know what that error message means.
1helpful
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
E:62:10
Hi, Error messages can be found at https://www.sony.com.au/electronics/support/articles/00008857. E:62:10 is a generic error of the stabilizer. After less than 3 years of use the stabilizer breaks down, making it impossible to take sharp pictures, and displaying the dreaded E:62:10 error message. This is a very well known problem that happens a lot and still today with Sony camera's. Thousands of users on the Internet have the same problem, read the website http://sony-e-62-10.atspace.cc/ or search E:62:10 on the Internet or on YouTube.
2answers
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
2helpful
Error : 10-FC12-0002 comes up during Toshiba system rocovery what does it mean and how do i fix it?
I download this from the Toshiba support site:
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D / 10-FC11-045D" -- may be caused by a faulty hard drive. *****
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
*for this error 10-FC12-045D u nid to call 1-800-457-7777 toshiba advance technical support they will send it to depot or they will recommend ASP (Authorized Service Partner)
I suppose your recovery disks could be bad. You can get another set from Toshiba. I'm also concerned about the health of the hard drive. Did you need to run recovery because the system crashed, because it may not have been an operating sysem crash but rather a hard drive crash. Have the harddrive or whole laptop checked by a reoutable repair person or check my website: www.micromendllc.com
3helpful
2answers
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
3helpful
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
1helpful
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
