Washing Machines Logo
K
Kris Foote Posted on Jan 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Making a terrible noise when water is going in on spin cycle.Ok when filling .Please help
Carmen Mikulic
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Jan 04, 2016
Carmen Mikulic
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
217493
Points
909
You hav debris in the drain pump. It's mostly rocks, pieces of glass or coins. You will have to remove them.
Making terrible noise when water is running on spray and spin .Ok when filling first off and on deep rince.Please help
You hav debris in the pump, such as rocks, glass oof coins. Please remove them from the pump.
2helpful
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
My Maytag Atlantis Mod.# MAV7600AWW doesn't come on with the cold water selected. It will come on with warm or hot water. The spin cycle seems to work ok when dialed to it. Before the washer seemed to...
the machine control opens both hot and cold water valves and then the machine sensor monitors this through a water temp sensor in the fill line till a certain amount of resistance is encountered so it could be a faulty sensor,machine control board or also if a certain type of wash is selected it wont use any cold water at all during the whole wash cycle
1helpful
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
1helpful
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
13helpful
3answers
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Top Washing Machines Experts
john h
