Hi Anthony:
A 4 prong plug is intended to handle 220/240 volt and also 110.
It has:
- Red and Black - 110 each 220 total
- White (neutral)
- Green (ground)
You will need to shut off the circuit breaker for your receptacly and then determine what power supply you have available.
You MAY be able to change your receptacle to handle your appliance.
I would NOT change the plug on your appliance as it needs both the 110 and 220 functions.
If you are not ABSOLUTELY SURE what you are doing, get an electrician. Not doing it right could start a fire or present the danger of electrical shock. WHICH HAS THE POTENTIAL OF KILLING SOMEONE.
Cheers.
