Samsung Galaxy S 4G Cell Phone Logo
Mark Brundage Posted on Jan 04, 2016
(?). I can see the turn on screen and the no sis card screen behinde my home screen how do i fix it
K7s741 mg no video output
Foxconn K7S741MG-6L Motherboard, 2004 new day1 relic?
is this true?, and yours or posted wrong model?.
NO VGA out? at mobo or the video card?
yes k7 , winfast board>?
answers,
SIS chips there are not supported, by (ALL)
No PCI-express slots at all , just AGP.(BAD)
1/2 of all AGP cards made will not work here, (dang)
no SATA ports, just relic IDE(PATA). sad max.
and the coin cell is dead at 10 year old now 2014
2014-2004=10 , spec is 7 year life so its dead and now BIOS goes MAD.(even igpu dead vga rear)
just found a raw mobo in a garage sale>??sure.
foxconn DIY sales, went dead 2012.
no video connected how , NOT TOLD , fail.
and now double dead, the mobo ended all support, gee how can they if SIS died. really/? nobody can !
and this too DEAD....
https://www.foxconnchannel.com/
buy a i3 mobo 2010 and newer
never buy into, SIS, VIA or Nforce ever.
it's junk mobo for only XP.
I will now tell this, horror, back in 2004 !
the VGA out is hard to get working on most then.
let me tell you why, (yes horrors of AGP)
1: 1/2 the AGP cards fail here unless from Foxconn.
2:the bios must be forced to the VGA you want to use and there are 3 choices then, igpu ,agp and pci slot.
one is the default and there was NO AUTO mode then.
best is to reset the MOBO using a new fresh coin cell RTC battery and then no APG card there at all.
and hope the igpu works.(mobo rear edge I/O plate VGA)
3: on some mobo (yes) I had to use very old PCI card, like this one for $10 used
ATI Radeon 9000 64MB PCI Video Graphics Card, With VGA, DVI & S-Video
this last trick if needed allows VGA bios to work
and then in the BIOS video page set it as you want
end legacy ,topic, PCI (non-express) video.
PCI old, is gone and forgotten now.
PCI-express modern/ 2003/4 up.but not yours.
avoid all AGP. the maker had a QVL on AGP that shows, only tiny list of allowed, and is max pain all that.
even bios updates that do not exist now..
Vertical smal lines in screen
row of dead pixels
the screen needs replacement
for temporary fix bend the screen carefully
or place a piece of carton behind the screen under the lid
(for the last one you probably need a screwdriver)
I want direct3d drivers for my machine which has
hi
u have many options
go to control panel>>display>>
change ur screen resulation 1024 X 768 and i hope ur problem will solve .
thanks mukesh
[email protected]
1helpful
SIS 315, 256-BIT AGP 4X VGA CARD VS GREEN ATI 7000 SERIES CARD
The ATI 7000 graphics cards are much better than the SIS 315 ones.
8helpful
Drivers for Sis 315 E 32 mb
ftp://ftp.inno3d.com/inno3d/sis/sis315e/sis315_v30755.exe
That is the latest driver I think is available for that card.
Thats about it really :)
Acer Aspire 3000 problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} No. JUST RESET YOUR BIOS SETTING TO DEFAULT. Your HD is OK
Computer not booting
Unfortunately it sounds like the processor fried. These are very prone to heat degradation.
Link to computer gate
Link2
Link 2 is to Geeks.com
Link 3 Take your pick
Your board supports Northwood/Williamette processors with HT
in 400/533/800 Front Side Bus
Unknown virus!
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn phone ON. Keep them pressed until the reset screen appears.
Give it time to reset.
Mar 15, 2008 • Nokia 6600
Problem in sis 6326
Well, first of all. Is it an LCD monitor? If so, it could be that some lights in the monitor has been burned. I had the same thing happen to me once, and it showed that it was the lighhts. Do you know if the computer reboots all the way to windows? If it doesn't, the problem could be that the power supply is not enough.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
