This remote control have no set-up code to Sansui. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
SOURCE: comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
