LG LMX28988ST Refrigeration : Refrigerator : French door Logo
Posted on Jan 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble shooting LG french door ice dispenser
My unit produces ice but does not dispense it. The water dispenser works but very slowly 16 seconds to fill 8oz and the ice seems to easily fall through and then freeze in a big clump. Then the motor is unable to turn and dispense the ice. There is a round plastic piece that looks like the metal rotating mechanism has scraped it but I can't figure out if this is the problem or if the dispenser is not correctly put together and shouldn't be allowing the ice down that far in the dispenser before being manually dispensed.
Hema Banavathu
Level 2:
Habit-Forming:
New Friend:
  • Expert 15 Answers
  • Posted on Sep 04, 2018
Hema Banavathu
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
15
Questions
0
Helped
13350
Points
108
Here you can find the solution for any kind of complications occurred in your LG http://aktechnoservice.com/lg-refrigerator-service-center-in-hyderabad
Trouble shooting LG french door ice dispenser - lg refrigerator service center in hyderabad-jmdt4jy3zjzrdue5nmvphq4g-5-0.jpg
Claude Kayser
Level 3:
Top Expert:
  • LG Master 9,098 Answers
  • Posted on Jan 05, 2016
Claude Kayser
LG Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061632
Points
28436
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Water dispenser very slow
Check the filter and replace if necessary.
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Icemaker does not work
Does your unit have the cube size selection button inside of the ice maker door , if so is it lit up, if so is it on a cube selection. If not that is the reason the ice maker is not working because even though the unit is on the cube selection has not been made. This should solve your problem.
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
