What is the sanitation cycle for on Model
Typically "sanitation" cycles require hot water....then they add more heat to the washer during the cycle. It is not 212 degrees, but it is very hot and does kill most germs.
The mildew smell is normally caused by water remaining in the system lines - because the water drain pipe is too high and keeps too much water inside after the system pumps the interior pan. Suggest that you just pour in some bleach after the last load...that should kill all mildew. Please do not overdo it. Only about 1/8th to 1/4 cup is needed to keep the mildew smell under control
