LOL, you're up the creek. Never buy a computer that does not have a CD Drive on it because that is what you need now.
May the AC Adapter Power Cord is bad. Some of them have a indicator light on them when you plug them in the wall. Does yours have a light on it and does it light up?
When you plug the power cord in the tablet do you see any lights?
SOURCE: How do I get my keyboard back on my dopo tablet?
it should also show little white boxes some where on the same page that is the key board. Otherwise the manufactory should have a manual if you don't. Did you also try just speaking into microphone and say keyboard it might bring up the keyboard I just tried on my tablet and it brought up the keyboard but I have a Samsung tab.
Testimonial: "This answer was not helpful but I can't change the result. It didn't answer my question, but I think it was because I didn't give all the details. Thanks anyway!~"
SOURCE: my Insignia WiFi Windows 8" Tablet will not charge please help
If it's under warranty, take it back.
Also check to see if there was a recall as the batteries may be unreliable.
If you know someone else who has one, check with their charger - your charger may have stopped working.
Hi J ....it sounds like you will need to do hard reset.this may be due to the latest app you installed or a failed update from google.
first... Switch off the tablet.....second hold the power button and volume up together for at least ten seconds....third let the tablet do what it does till you see the android robot with red triangle....wait....then input from the menu offered ....usually you will need to reset the tablet to factory install.this is a pain but in future disable auto updates if you can.. Tell it to let you manually install.once you have the tablet back sign into you google play account.that should remember your purchases and help you reinstall .unfortunately you will lose all the private info and pictures.for what it's worth if you do decide to make another pattern draw it on some paper and photograph on another device.please vote if this helps you.have a nice weekend.
they are all pretty much the same just go by another tablet screen change and just be carful with the ribbons ,
