Question about Cell Phones
How do I connect to iTunes from my disabled iPhone?
My iPhone is disabled, without service, but when i turn it on it says, connect to itunes, and i forgot my passcde too
    Top Expert:
  • Cell Phones Master
  • 9,098 Answers
Iphone is disabled connect to itunes HOW???? ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jul 26, 2012 - i have connected my phone to the computer and nothing. phone still reads disabled connect to iTunes. frustrated!!!!!!!!!!!!!!!!!!!!!!!!! iPhone 4. My Iphone 4S is disabled and says connect to Itunes but i can't as ...
Jan 26, 2014
to allow acesss please respond on your iphone, ...
Nov 27, 2013
ipad is disabled connect to itunes
Aug 11, 2013
iPhone is Disabled connect to iTunes
Mar 14, 2013
More results from discussions.apple.com
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - ... forgotten your passcode, or if a message says that your device isdisabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't sync or connect with iTunes, use ...
iPhone 4 Disabled but cant connect to iTunes to fix it ... - iFixit
Posted on Jan 07, 2016
6ya staff
SOURCE:
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
How can i unlock my iphone 4s
If your iPhone is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
How to Unlock Disabled iPhone with without iTunes
Jan 08, 2017 | Apple iPhone 4S
How do i unlock my iphone
You can put your iPhone into Recovery Mode to unlock it. This will allow you to restore it without needing the passcode.
Step 1. Disconnect all cables from your iPhone and turn it off.
Step 2. Press and hold the Home button and connect your iPhone to iTunes. If your iPhone does not turn on, please turn it on manually.
Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode.
Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone.
Step 5. Once the restore process is complete, you'll be prompted to setup your iPhone as if it were new. If you have an existing backup, you'll be able to load it.
Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you unlock a disabled iPhone with Recovery Mode. Therefore, please consider carefully whether you need to use this method to fix the issue.
Dec 20, 2016 | Apple iPhone Cell Phones
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
How do you enable iphone 4s ios7 without computer or icloud?
I'd contact the seller and see what's going on. It could be a stolen phone. Disabled means that someone entered the wrong passcode too many times, and you WILL need a computer (iTunes) to restore it.
Aug 09, 2014 | Apple iPhone 4S
How can i enable my disabled iphone without itunes
You'll need iTunes, and specifically your own computer- or you'll have to erase everything by putting it in recovery mode.
Here's how to do that:
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Aug 09, 2014 | Apple iPhone 3G
Reset disabled iphone without using itunes
You can also unlock your disabled iPhone using the Find My iPhone website, as long as your iPhone was registered with your Apple ID and Find My iPod was enabled in the iCloud menu. This will only work if the iPhone is currently connected to a wireless network. Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
reset-iphone-password-with-icloud-find-my-iphone-153nizovceagjad0jf0jsact-3-0.jpg For more ways, check: How to Unlock A Disabled iPhone with/without iTunes
Dec 09, 2013 | Office Equipment & Supplies
Disabled fix without itunes
If it says to connect to iTunes there is nothing else that you can do. Just connect it and it will solve the problem immediately.
Nov 07, 2013 | Apple iPhone 3G
Cell Phones Logo
224 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
