It wont fill up tubes rite or tight enough.
I am going to go under the assumption you are using 100mm tubes. I just switched to kings to make life easier but here is how I filled my 100mm to the filter with good compaction and a trick to get it to the filter. I tightly pack the tobacco against the left side, sticking my finger in the chamber and pushing pretty hard to compact to the left side, I then just do a light poke for the rest of the compartment. Here is the trick part, take a finger and put light pressure pushing on the filter towards the machine, but not so hard it bends the tube and also no so hard that when the injector probe comes out it pushes your finger away from the machine. Using this method I would get around 9 good packs with one redo out of 10 injections. The key is to have enough pressure to hold the filter at the point where the plastic tab usually pushes out and then let the probe push your finger away from the machine. Only very light pressure is needed to make the difference. If the cigarettes are not packing tight you are not compacting enough tobacco in the chamber. There is a fine line though, you need to find the balance as stuffing too much in will cause it to bind up, you just need to find the balance. Once you figure it out it will go very quick, I stuff mine while on the phone and can do around a pack every 2 to 3 minutes or so and get a cigarette that can not be distinguished from a store bought one.
Another tip: I use old cigarette packs as containers for my DIY smokes, you can do the same here with a plastic case. If I do get some that are not fully pushed against the filter using the above method, or if the pack just seems a little loos I put them aside and at the end I load them all in cigarette packs just like they come from the store, filter up (otherwise I have a habit of smoking filters from years of them being positioned this way!) and once the pack is full (add good ones if there is space for them to move around, it will not hurt them) turn the pack upside down so the lid is on the bottom. Now tap them firmly about 10 to 20 times against a hard flat surface. This will move the tobacco towards the filter if there is a space or pack loose cigarettes.
Warning: From my experience :) Do not over stuff the machine or using the compacting method do not over pack the tobacco, find a good medium. If you over pack the smokes will be solid and very hard to drag from. Do not smoke cigarettes that are hard to rag from, the extra force needed by your lungs followed by introducing smoke into your lungs will result in pain and maybe worse, but I only made that mistake once.
Tried the above answer and did not come close to working but the cherry falls off since there is not much holding it in place on the bottom of a 100 cig. Plus you run the risk of jamming the machine with too much tobacco.
The spoon doesn't travel down inside the 100 paper tube far enough so my suggestion is to buy king size tubes since that's what its trying to fill anyway and is all you get even with 100 tubes.
With the suggestion above, you run the risk of jamming the machine and or burning out the motor. Not worth it.
Also with 100s, you have an 80 percent chance of the cherry falling off near the filter due to no tobacco other then paper to hold it in place. Can really ruin furniture, pants and shirt sleeves. ;)
Since you are getting king size tube fills anyway using 100 tubes, buying 100 tubes is a waste of money,
This is a great machine but use king size since that's what its trying to fill anyway.
you need to add or minus humidity, get it just right and you will know it. That OR you need to replace the rubber bumper that holds the paper on the nipple for a good roll.
