Locks & Locksmithing Logo
Anshul Posted on Jan 08, 2016
By mistake i have locked my american tourister luggage bag and now i can't open it, i forgot the 3 digit combinations. please tell me solution how i can unlock it
Echolac Bag Combination Lock. How can I open my bag when I forgot my 3 digit code please?
Question edited for clarity, change spelling of maker, ecolac to Echcolac, change verb 'forget' to 'forgot', turn question around, 'make (what it is)' first in question, add magic word at the end.
Question moved from Cars and Trucks category to Luggage.
Pick it by inserting a shim between the dials until you feel the 'flat' section on each wheel. The rotate them all together until the lock pops. Or you can put a little pressure on the lock and feel when the wheel goes loose and feels different. Look at 'The Lock Picking Lawyer' on YouTube and search his channel for TSA Lock.
https://www.google.com/search?q=open+my+ecolac+bag+when+I+forget+my+3+digit+code
2answers
I have got a new american tourister trolly bag. The unlock key was 000 but its not unlocking my bag. What should i do ?
That is common problem on american tourist er luggage. You cheek your luggage note book and check security system. I think you find some idea. Are you want to new luggage for you and that is very comfortable for you visit this site and get many Idea about luggage. Best Luggage Sets Top Models For 2017 To Start Traveling .I follow this site after 2 years and get many idea about luggage.
2answers
Is first bag free
To both questions, "It depends on the airline."
While there are standard baggage sizes across some of the major carriers, it is prudent to check the airline you will be traveling upon regarding luggage fees, size allowances, and just what can be carried on and what must be checked. Plus, you have to know what you may carry in carryon luggage, what you can not take, and what can not be carried in checkin luggage. And weight is a factor as well.
By mistake I have locked my american tourister luggage bag and now I can not open it I forget the 3 digit combinations. How I can unlock it
Few standard combination locks are machined to such a high degreee of precision that when the lock is put under strain one or more of the numbered rotating dials is not left a little loose while the other(s) become tight.
It is a matter of slowly turning the tight dial or barrel until it becomes loose. At this point the lock will move a little as long as it is kept under strain and one of the other numbered barrels that was previously a little loose will become tighter and so it is time to slowly turn this barrel and repeat until the lock releases.
Practice on something like a cheap cycle lock and you will discover the trick that is increasingly difficult as the quality of the lock improves.
It takes a light touch and lots of patience. So far I have even opened a quite expensive combination padlock this way but it relies on imperfect manufacture. It would be quite impossible to use the technique on a perfectly made combination lock.
2answers
By mistake I have lock.my american tourister trolly lock
If you have never set the 3 digit lock code the default lock code from the factory is 0-0-0
Aug 03, 2016 • Photography
It's locked and everything imp like my clothes atm etc is inside I am using this bag for first time but it's not opening up
Dial the three wheels to 0-0-0, which is the default combination setting for American Tourister and Samsonite luggage.
Try this setting
Feb 24, 2016 • Vacuums
55helpful
15answers
How to Unlock an American Tourister Suitcase's Number Lock
<b>• Place the suitcase right side up and look at every number wheel to find a hole at the bottom.
• Bring the holes of the three wheels in the same position.
• Now keep holding the button as to unlock and rotate the 1st wheel and reduce its number by 1.
• Repeat the same process with the rest of the two wheels.
• Again start with the 1st wheel and reduce another 1 position.
• Attempt the whole process for the third time and your suitcase will get unlocked.
</b>
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
