I have repeated the process several times. At the Beginning of the cycle, the machine locks, the red locking light turns on, and it starts. About 20 seconds in, the red locking light shuts off, but the locking mechanism is still locked, and then it gives the de error code. If I can get it further into the cycle, at some point it goes through the whole cycle without a problem. Any ideas?
SOURCE: DE error code
That is a door switch error problem. The door latch is not sensing the door closed. You may need to replace the door latch assembly.
SOURCE: Machine won't start, lights are all on and ready to wash
this may be due to heavy load , if there is heavy load then also the machine will not start but the lights will glow
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: LG WM2277HW dE error code coming
Hi
Thanks for using FixYa. DE is a door open error, you’ll have to check the door if it’s properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: I have a LG WM1814CW washer that has started
You may have a problem with the ball sensor. Look in the back of the washer. On the right side as you're looking at the rear, does the frame look slightly dented in?? If so, you will need to pound out the metal. The reason is that the ball sensor is located on the lower right side of the back panel and if it is pushed in enough, the spinning movement from the tub will knock the ball sensor causing the control board to display UE error code. Good luck
