Vizio 50-Inch LED Smart HDTV 1080p Full HD 120Hz - E500i-B Logo
e
earl hinton Posted on Jan 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my problem with my vizio tv is that i there is no picture or sound.i tried turning off/on but nothing happens
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Jan 11, 2016
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986650
Points
237762
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1helpful
Vizio m420nv tv wont turn on but logo lights up
Test the PWR-ON terminal on the power supply and see if you have about 3.5 volts there
1helpful
I have a Vizio E472VL television. When I go to turn it on the logo appears on the screen and the "vizio" icon back light turns on, but nothing else happens. I have tried coax, component, HDMI, etc..
Had the same thing happen to my Vizio TV. It was on warranty, and they replaced the motherboard. It's been fine since then. There appear to be only a very few parts inside. Power supply, motherboard, and display. That's it. Your power supply is good, as is your display. You just need a motherboard.
Screen went gray during program. can't turn on or off by remote but can by tv button. cable checked out fine. is there a reboot button other than disconnecting power (which I did) the vizio name lights...
Hi
It sounds to me like you have a bad main board.
But it you may be better of by buying new TV
those boards run over $300.00.
You know the prices of a new TV's !!
Good Luck
Vizio have a parts distributor- Vance Baldwin you may give them a call, or call Vizio to find out if they have anybody else.
2answers
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Vizio 47
It sounds that the main board has got faulty. Seek check support.
2helpful
I have a vizio 42 plasma model #vp422hdtv10a when i try to turn on the unit it makes 2 click sound like it is turning on but nothing happen. i open up the unit to look for popped capacitors but i see non...
I am having the same problem with my 42" vizio tv. When plugged in the standby light is on and when turned on the light switches from orange to white, however there is no sound and no picture. I am hoping to find what is wrong with it so i can get it fixed. Or atleast by the correct parts! I have only had my tv about 2 years
1helpful
I had some water from my plant dripped in my 32 inch Vizio LCD tv. Th e tv was off when this happened, so I try to turn it on and nothing happened. I try to dry it out with a blow dryer on warm heat. It...
You should let it sits for at least 72 hours. does the TV have a orange Vizio logo light when you plug in the power? what about when you turn it on, does the Vizio logo light turns white? if yes to these two questions and you still does not have picture or sound, it could be your main board or inverter that got fried.
2helpful
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
