the link below is for Daewoo,
press the helpful button
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
SOURCE: -I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
