Refrigerators Logo
I
Ian thomas Posted on Jan 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer bleeps as if door open. Temp goes down on its own
Defrosted freezer when first started doing it. Did help but started again
Claude Kayser
Level 3:
Top Expert:
  • Refrigerators Master 9,098 Answers
  • Posted on Jan 12, 2016
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063584
Points
28436
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
2answers
Whirlpool FRBB2VAF20/0 side by side fridge freezer derosting
If the door gasket is weared, that can be the cause for this problem, check if it is in need of replacement.
1helpful
2answers
The freezer is working but the fridge is not. We unplugged and defrosted it for 24 hr and it was fine for 1 week and now it's doing it again.
Assuming that the fan in the freezer is working, then your auto defrost system has failed- either the timer or the defrost heater assembly(heater and defrost thermostat)
Everything in the freezer defrosted because i left the freezer door open for about 8 hours how long will it take to refreeze i feel the cold air blowing inside the freezer. its been 4hours already
Hello there:
If every thing has been defrosted it should take about 6 to 8 hrs to fully freeze again now that is also depending on how you have the freezer temp set i would set the temp so that it gets the coldest that it can than after the food has frozen than reset it back to you setting that you had before ok
Hope this is very helpful for you
Best regards mike
1helpful
Freezer has defrosted on its own. Red freezer high temp light will not go off.
Door has accidentally been left open. Have missed a proper defrost and ice has built up internally. Switch off and do a 12 hour defrost. then switch on again. (Thats where i would start.).Because fan is stuck in the ice, it cant blow cold air to the sensor. Sensor detects this and shows red error light.
1helpful
Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
[email protected]
12helpful
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
Has been bleeping a while, then fridge got warm, then freezer defrosted!
So the freezing element in your fridge is broken and it's beeping because it gets below a certain temperature ?
5helpful
Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
2helpful
Freezer not working
there is a defrost fault - quite common with these hotpoint. fault could lie with the module or stats associated with defrost or possibly the heater itself. most probable is the module but impossible to localize by remote control. water drains away thro a hole in the centre of the tray underneath the evaporator
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
