SOURCE: tray not ejecting
check the door belt wich is placed underneth of the driv mechanism.if the belt is not broken or getting loose in size then check the motor pully then motor. best wishes do with care.
SOURCE: Digital Apex dvd/cd/mp3 player tray won't open
on the bottom under the dvd tray is a hole. inside the hole is a white plastic gear that opens the dvd tray. it is stamped with a phillips screwdriver depression. insert a phillips screwdriver and rotate to open tray/
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
SOURCE: cd stuck
wow...that's a little tense..only way I know is with long needle nose(but be careful with mechanism) or talking apart the laptop(takes around 35 min and loads of patience) so you can slide it out from inside.
SOURCE: Conia M580 DVD player has
Easy... follow these instructions
Testimonial: "Many many thanks for your help - your instructions were dead-easy to follow and I've now successfully rescued my much-prized "Black Books" DVD disc!!!"
