LG WM2487H Front Load Washer Logo
P
Paul Shumaker Posted on Jan 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove pedestal from washer
How do i remove pedestal
Level 3:
  • LG Master 19,187 Answers
  • Posted on Jan 13, 2016
LG Master
Level 3:
Answers
19187
Questions
0
Helped
4345864
Points
82261
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Frigidaire gallery remove pedestals
There should be a bracket on the front and back of the pedestal with screws going into the bottom of the washer or dryer. Many times it is inset so you do not normally see it. Remove the screws in the bracket and it should come right off.
If you do not have brackets it might be screwed in from within the pedestal body in which case you would have to take out the drawer to get to the screws.
1helpful
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
2helpful
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
17helpful
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
How do you remove the washer from the pedestal?
not an easy task---try to remove the drawer. there is a bolt going upwards in each corner (inside)
2answers
Vibration
Does it have runner pads on the leveling feet on the washer resting on the pedestal?
If so, and it still moves all over, you will have to fasten the washer to the pedestal with bolts and nuts. I had a GE that did the same thing. I finally laid them on their side, drilled out the holes to fit bolts and washers I bought from Home Depot. They really don't make that clear, do they?
Sirwriter
1helpful
2answers
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
