HP Compaq 6715b Notebook Logo
K
KEN MCCOY Posted on Jan 15, 2016
DVDRAM GSA-T20L NOT RESPONDING TO cd
REPLACED DVDRAM NOT WORKING
  • Matthew
    Matthew Jan 17, 2016
    Is it connected properly?
5 Related Answers
Anonymous
  • 200 Answers
  • Posted on Sep 06, 2008
SOURCE: HL-DT-ST DVDRAM GSA-T20L ATA Device
ok you can do two things to fix it
first of all go to start
go to run
type regedit and hit ok
now in the registry go to this path
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
and remove both upper and lower filters from the right pane
now close the registry editor.
reboot the computer and see if that fixed it or not
if not the download the drivers from this website.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3224052&lc=en&cc=us&dlc=en&lang=en&cc=us#
just select the operating system that u have and then download it and reinstall the driver and then reboot the computer
that should be it
if still not working then i guess its a hardware issue
cheers
Jerry Pal
Jaipal Reddy
  • 130 Answers
  • Posted on Jul 25, 2009
SOURCE: Disc drive not working! Urgent help needed!
Hello
i will provide you a link where you can download a fix. With this fix you can resolve the issue.
Run the following fix on the notebook and restart the notebook :
http://techiesspot.com/filez/cddvdfix.reg
I have fixed 100's of laptops with this issue
Anonymous
  • 247 Answers
  • Posted on Oct 22, 2009
SOURCE: hl-dt-st dvdram gsa-t20l has stopped working.
try this first,,follow the link verify operating system
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-46803-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224052
you may need to install updated firmware for the optical drive,but they are giving me any download options,you will have to start here,download the 4 troubleshooting programs and run them ,if they cant fix the problem,im guessing that a firmware download may appear,let me know what you find,verify operating system before downloading good luck
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00828604&tmp_track_link=ot_recdoc/c00820047/en_us/c00828604/loc:4&lc=en&dlc=en&cc=us&product=3224052
Braza_Dude
Vincent Martins
  • 15 Answers
  • Posted on Nov 21, 2009
SOURCE: HL-DT-ST DVDRAM GSA-T20L ATA Device not detected.
Goto to this Microsoft site and apply this fix.
http://support.microsoft.com/kb/314060http://support.microsoft.com/kb/314060
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jan 27, 2010
SOURCE: HP dv6636nr DVD/CD not working
This is a common problem try this: Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
4helpful
3helpful
HL-DT-ST DVDRAM GSA-T20L ATA Device Code 19 My
sure ...just look for the driver on your laptop site ..and reinstall it ...this should fix the problem ..if not ...restoring the OS or reinstalling it will fix it too
HL-DT-ST DVDRAM GSA-T20L ATA Device cannot read DVD
first of all check that ur laptop is not infected by viruses,because sometimes it happens due to virus...
make sure that the DVD you r trying to run is scratch free....ans is clean...
1helpful
I need firmware for HL-DT-ST DVDRAM GSA-T20L ATA
I have the same problem and after two months (I'm a total beginner), I finally stumbled on this site.. check it out and if you can help me I would appreciate it. I downloaded the update, but I can't figure out what to do with it to make it work. I hope it helps.
Tony
http://h20239.www2.hp.com/techcenter/lightscribe/index.htm
1helpful
Cd-dvd room driver
i have built in this hardware.it was used before but suddenly is not working.what i think some how the driver is missing.
2answers
HL-DT-ST DVDRAM GSA-T20L ATA andDual DVD's
HellO:
I have this same unit. And yes it does support dual layer. I used it to make my restore disk.
also lightscribe.
Check the jumper on the cd/ dvd rom drive. maybe it was still there. I tried before to remove it. The os installation continued after i Removed it.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
