SOURCE: keurig coffee maker does not make a full cup,
Check the needle to make sure it's not clogged. You can completely remove the k-cup holder and wash it out with your kitchen sink sprayer to help remove any obstructions. The manufacturer even recommends using the tip of a small paper clip to help push out any debris if needed. Then try brewing a cup of just water on the largest setting without a k-cup in it. Hope that helps! Best of luck...
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Testimonial: "Thanks so much for the help. I already use Brita filtered water, so it's good to know I'm on the right track!"
SOURCE: pump starts then stops. I have cleaned all holes.
Mine would only very loudly pump a partial cup after about two years of use. I tried everything, including descaling. Even held my mouth different ways. I took it apart three times, the last time intending to glue all the rubber hoses. By accident I discovered a plastic "filter" in the intake line just below the water reservoir. I removed it, cleaned it out on both sides with a toothbrush, put it back in, and now it works like new. The filter is easy to get to if you take the bottom metal plate off: 5 screws for that, then two screws in the filter unit directly under the reservoir. You get to it from underneath the coffee maker. Pull the black cover back to expose the plastic hose, then pull the black filter out.
It is easier to do than to describe.
I have not seen this fix anywhere on the net, but I can verify that it works.
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Before trying to descale, take a paper clip, bend is straight for about 1" and run it into the pins at the K-cup holder...
Check out this tip about how to
descale your Keurig coffee brewer
How
to Descale your Keurig Coffee Brewer
heatman101
How
heatman101
How
heatman101
How
heatman101
How
heatman101
